unidentified electromagnetic shaker
Discussion in 'Datasheets, Manuals and Component Identification' started by lou123, May 14, 2012.
  1. lou123
    lou123
    8
    May 14, 2012
    Hi everyone, I have been lent a small electromagnetic shaker, see attached pictures. The owner used it a long time ago (ten-twenty years?) and cannot remember what make or model it is, only that it should vibrate a few mm. It has a metal mounting plate attached to it. It is about 70mm height, 65mm diameter with a 40mm stinger rod.
    I cannot find any sort of marking, and I am wondering if anyone might know what make it is? I realise it's a very long shot but would like to know its spec...etc I presume there will be a marking inside but I don't want to dismantle it since i'm not familiar with kit like this.
    Any help greatly appreciated, thanks :)
  2. shrtrnd
    shrtrnd
    3,734
    477
    Jan 15, 2010
    I don't recognize it. Did it come off a larger assembly, that you might be able to get
    a manufactuer's ID from?
    It's probably pointless to disassemble it to try to ID it, there's rarely any informaion
    inside the housings on a small assembly like that.
    You may have to just start contacting places that manufacture them, and see if they
    have an off the shelf equivalent, or will make a compatible equivalent.
    Oftentimes I've found a shop that will make what I need. I send them the original,
    and they make one for me. Not cheap, but an option.
  3. lou123
    lou123
    8
    May 14, 2012
    Hi, looks like I solved my problem- I contacted some manufacturers, it seems to be a very old LDS v101 (LDS now owned by Bruel and Kjaer). Probably too old to be repaired by them though...
  4. shrtrnd
    shrtrnd
    3,734
    477
    Jan 15, 2010
    You never know. If that division is still in business, see if they still make an
    equivalent, or service old assemblies. Oftentimes if the manufacturer doesn't still
    do the work, they know a rebuilder who does work on their assemblies.
  5. Shaker Maker
    Shaker Maker
    Sep 5, 2012
    Hi , Yes that is a LDS V101 Shaker, LDS are still going strong and but are now know as Bruel & Kjaer VTS.. They will be able to repair it as they still make them.
