P
Pimpom
I haven't closely examined many different computer PSUs. The ones
I've taken apart are mostly cheap Chinese ones and they're all
closely similar. Most of them use a TL494 or an SG3525 as the PWM
controller. Today, I happened to look at an old ATX PSU PCB which
uses a chip I'm not familiar with. The number is LPG-899 and it
has "Linkworld" printed in cursive font. The logo is a filled
triangle with a globe inserted half way on one side. Curious, I
searched for a datasheet but couldn't find one. That made me even
more curious and I kept on searching for some time, without
success.
It's in a 16-pin DIP package but the pin-outs are different from
the ones I know about. The push-pull outputs are taken from pin 7
and 8, driving two C945 transistors (Japanese low-power NPNs)
which in turn drive the output transistors.. The +5V output of
the PSU is fed back directly to pin 2, so this looks like Vcc.
The +12V output is goes via a resistive voltage divider to pin 3.
Pin 5 is grounded. I didn't check the rest. Is anyone familiar
with this IC?
success.
with this IC?
