Understanding Vacuum Tube Diagrams?
Discussion in 'General Electronics' started by Chris Cooper, Nov 10, 2003.
  1. Chris Cooper
    Chris Cooper Guest
    I've got an old wire record I'm trying to revive (see my "Reviving 50+ year
    old Wire Recorder" post), one of the problems is that I don't quite
    understand how to interpret the schematics for the vacuum tubes. Is there a
    simple explanation (online preferably) that talks about the "standard
    symbols" used in vacuum tube internals?
    Thanks!
    Chris
  2. Robert Baer
    Robert Baer Guest
    The reference that Jack gave is good for theory, but does not appear
    to relate diagram(s) with terminology.
    It is getting too late for me to scan some info for you; here is a
    "quickie" ASCII pseudo-art:
    _______ <--- plate (crude)
    ----- - - - - <---- grid (sort-of crude)
    __________
    | ^ | <---- cathode (crude)
    | / \ <-------- filament
    Have data on a large number of tubes and can scan what i have for you.
    Will see if i can find something better Monday evening (later today).
  3. GPG
    GPG Guest
    http://www.allaboutcircuits.com/vol_3/chpt_13/1.html
  4. tiger x
    tiger x Guest
    A real simple explaination of vacuum tubes:
    1. The source of electrons is the cathode.
    2. To release electrons, the cathode must be heated by the filament.
    3. Released electrons must be attracted & gathered up by the plate.
    4. The flow of electrons through the tube is regulated by the control
    grid.
    5. Any other grids in the tube are for effecient operation of the
    tube.
    6. The cathode has a negative potential.
    7. The plate has a positive potential.
    8. The control grid potential varies according to the input signal.
    9. On a schematic, the control grid is the bottom grid and enters on
    the left of the tube.
    10. The signal out of the tube usually leaves via the plate (top), but
    may leave via a resistor connected to the cathode (bottom).
    Easy as that!
    Tiger
  5. Dbowey
    Dbowey Guest
    Unless the tube has no "cathode." Older tubes used the filament as the negatve
    element, so AC could not be used for the filament voltage, for hum
    considerations.
    Don
  6. JeffM
    JeffM Guest
    Dbowey
    Tube rectifiers still do.
    The classic H-K short (heater-to-cathode) can also cause hum,
    defeating this design consideration.
  7. Dbowey
    Dbowey Guest
    jeffm posted
    *some* Tube rectifiers do, not all do.
    When did we change over to discussing defective tubes?
  8. Mike Eno
    Mike Eno Guest
    Man you must be a young buck not to know about vacuum tubes ;) or i'm
    just
    an old #art. Wet behind the ears but interested in 50 year old vintage
    electronic devices, all right then.
    I know this is a late response but ...
    Vacuum tubes share a lot of similarity to Depletion mode MOSFETs in
    terms of the design equations. Mind you tubes require much higher DC
    operating voltages plus the aformentioned filament juice.
    Source Gate Drain are analagous to Cathode Grid Plate.
    MENO
  9. Robert Baer
    Robert Baer Guest
    ....and....i, as well as others posted labelled drawings and links to
    numerous references.
    Dead issue by now.
