underground fault locator
Discussion in 'General Electronics Discussion' started by jaimin parmar, Dec 28, 2013.
  1. jaimin parmar
    jaimin parmar
    Dec 28, 2013
    Hi
    i am making under ground fault locator project and i am confused how can i sense dc current in cable and how i display the distance on lcd using microcobtroller
    so plz help i am new in electronic world
    thanx
  2. (*steve*)
    25,496
    2,837
    Hi Jaimin, welcome to Electronics point.
    In general, you sense DC current by means of the magnetic field it generates. However the strength of the magnetic field depends on several things, current and distance being the most obvious.
    To put it simply, if one is unknown, it is pretty much impossible to figure out the other one.
    What related experience do you have? This sounds like a very ambitious first project to me.
  3. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    In determining how to determine were a fault is, you need to define what constitutes a fault:
    1. Normal/degraded signal/current/voltage on the conductors
    2. Fault Open (full or partial)
    3. Fault Short (full or partial) to external conductors
    4. Fault Short (full or partial) between internal conductors
    If the conductors are not shielded in steel conduit there are RF radiating signal tracers that may work. But this means walking the path of the cable, not a digital display. Otherwise research time-domain reflectometers.
    Ken
  4. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    If you want to induce a current into your measuring device you can only do this if the magnetic field is changing. Otherwise you have to measure the electric field. If you are able to connect to one side of the wires you could make a TDR which sends out a pulse and measures the time for the signal to come back. You convert this to distance and your done. This will pick up open circuits and shorts.
    Just a thought
    Adam
  5. shrtrnd
    shrtrnd
    3,821
    519
    Jan 15, 2010
    I'm with Arouse1973. Look up information on TDR's (Time Domain Reflectometers).
    Most industrial electronics now is switching to fiberoptics, but in the (not too long ago)
    'good old days' we used TDR's to determine the length of cable (wire) runs across the
    plantsite using a TDR. Cable salesmen that came to the plant used their own TDR
    to determine exactly how many feet of cable (wire) were left on their reels for sale.
    You can find them on ebay, if you're serious about using one, finding out how they work.
