UltraSonic Transducer.
Discussion in 'Sensors and Actuators' started by HellasTechn, Mar 1, 2020.
  1. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    Hello everyone,
    Like i mentioned in my other post here :
    https://www.electronicspoint.com/fo...er-interface-for-arduino.292520/#post-1795054
    I want to build my own arduino based fuel injector cleaner. Further more i have seen theese ultrasonic cleaners that work pretty well. Does anyone know how to use ultrasonic transducers ?
    I found a few on e-bay :
    https://www.ebay.com/itm/Aluminum-A...epid=0&hash=item3cf65ca776:g:NtgAAOSw34FVGgIs
    What is their rated voltage and current, how can i drive them. I suspect that it takes 30-40Khz pulses of high current but im not sure.
    Any insight is welcomed . Thank you !
  2. bertus
    bertus Moderator
    682
    236
    Nov 8, 2019
  3. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    I bet the transducer itself runs on lower voltage. The driving circuit is there to turn the 50/60Hz mains supply to 28Khz . If that is the case then i could use the arduino to produce the 28Khz and mosfets to supply the pulsed voltage to the transducer.
  4. bertus
    bertus Moderator
    682
    236
    Nov 8, 2019
  5. HellasTechn
    HellasTechn
    1,524
    212
    Apr 14, 2013
    Well its probably the same i suppose. So the transducer and driver circuit are what i need.
