F
Franc Zabkar
I've been trying to understand the theory behind the design of the
Ultra-LD 200W Power Amp Mk2 in the Aug 2008 issue of Silicon Chip. The
amp uses On Semiconductor's NJL3281D/NJL1302D ThermalTrak power
transistors. These have integral diodes.
This is the full circuit:
http://us1.webpublications.com.au/static/images/articles/i1107/110797_10mg.jpg
Photo of amp module:
http://us1.webpublications.com.au/static/images/articles/i1107/110797_12mg.jpg
Bias circuit:
http://us1.webpublications.com.au/static/images/articles/i1107/110797_9mg.jpg
The article:
http://www.siliconchip.com.au/cms/A_110797/article.html
Transistor datasheet:
http://www.onsemi.com/pub/Collateral/NJL3281D-D.PDF
In the absence of an adjustment, how can you guarantee that the
quiescent current settles at a level that is optimum for crossover
distortion and power dissipation purposes? Wouldn't the actual bias
current be highly dependent on the characteristics of Q10 and Q11?
Would a standard Vbe multiplier arrangement where DQ12/DQ13 and
DQ14/DQ15 were wired in parallel (with series resistors ?), and
Q10/Q11 were at ambient temperature, be a better way to do this?
Wouldn't that guarantee optimal thermal tracking, and wouldn't that
allow the amp to be optimally biased?
BTW, the article states that the quiescent voltage across the 0.1 ohm
emitter resistors is 70-100mV. I believe this should be 7-10mV.
- Franc Zabkar
Bias circuit:
The article:
- Franc Zabkar
