N
N_Cook
As found on Crate GLX65 combo of 2004, miniature pots with clear plastic
shaft and illuminator bulb inside the pot. Independent source that is.
For future reference, as in for mechanically broken switch, all the pots are
fine. Only 4 years of normal use and yet again flimsey push/push switches
are falling apart. Will replace those with robust conventional toggle
switches, enough room after bending the pins, and only SPST use although
they are DPDT switches.
