UHF + UHF Antenna Diplexer
Discussion in 'Electronic Design' started by Rodney Josey, Jan 17, 2005.
  1. Rodney Josey
    Rodney Josey Guest
    If I've posted to the wrong NG for this then please advise...:)
    Does anyone know if there is such a thing as a 'diplexer' for combining two UHF antenna's each
    pointing in different directions into a single cable prior to being input into an antenna amplifier
    I have need of 2 x UHF antennas - main one facing north for 4 free-to-air channels & a secondary one
    facing to the south for a separate single free-to-air channel. Now I can get a 'diplexer' for
    combining a VHF antenna plus a UHF antenna into a single cable which on taking one apart shows that
    the VHF side stripline resistive load is different than that used on the UHF side - so NO GO for
    using such a 'diplexer' when I need to combine 2 x UHF cables together into the one cable feeding
    into the input of an external aerial amplifier.
    Any ideas on what I could do to get this ?
    Oz-Rod
  2. combining two UHF antenna's each
    Yep - off the shelf stuff - try Alvin or Hills (assuming you are in OZ)
    73 de VK3BFA Andrew
  3. Rodney Josey
    Rodney Josey Guest
    Thanks Andrew. Am considering using a UHF splitter in reverse - hopefully the 3db loss will be
    compensated for in the masthead amp mounted a few feet below the two antennas.
    TIA.
    Oz-Rod
  4. Try something called a JoinTenna from ChannelMaster. I bought one from Dow
    Electronics (google that). You have to specify the channel you are adding.
    For example, I use a VHF/UHF to pick up all but one station. That other
    station comes from the oppposite direction, so I have a UHF pointed that way
    and join it to the other with a channel 10 JoinTenna.
    Regards.
