UART, ATE.
Discussion in 'Electronic Design' started by Boki, Jun 17, 2005.
  1. Boki
    Boki Guest
    Dear All,
    UART
    A circuit <=========> B circuit
    || UART
    ATE circuit, choose by Tristate gate.
    Sometimes the A circuit's TX signal can't be received by ATE circuit.
    Best regards,
    Boki.
  2. Ah... the weekly challenge
    What tristate are you using?
    martin
  3. Pooh Bear
    Pooh Bear Guest
    Timing ?
    Graham
  4. Lack of Timing?
    martin
  5. Boki
    Boki Guest
    um... it seems to be no....
    Should I add something to help ATE circuit to receive signal from A
    circuit? or just put them together is ok?
    Best regards,
    Boki.
  6. Pooh Bear
    Pooh Bear Guest
    Have you heard of something called 'framing error' ?
    I suspect not. Suggest you look it up.
    Graham
