Type of wires
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
RS-232 is very tolerant. You can use almost anything.
With longer runs (higher resistance and capacitance) you tend to just lower the speed.
davenn
14,262
14,262
how to find capacitance of it?
what run length are you going to be doing and what baud rate do you want to use ?
ohhh and what cable do you want to use ? shielded or unshielded?
CAT-5 ?
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
Make a coil and measure its resonant frequency with a known capacitor and a grid dip meter.
Use the cable instead of the capacitor to calculate the capacitance. The cable length must be considerably shorter than the wavelength of the frequency in use.
AnalogKid
Jun 10, 2015
2,893
Jun 10, 2015
2,893
From two websites:
The specification recommends 24AWG twisted pair cable with a shunt capacitance of 16 pF per foot and 100 ohm characteristic impedance.
The standard also states that the maximum cable length is 50 feet, OR the cable length equal to a capacitance of 2500 pF. The latter rule is often forgotten. This means that using a cable with low capacitance allows you to span longer distances without going beyond the limitations of the standard. If for example UTP CAT-5 cable is used with a typical capacitance of 17 pF/ft, the maximum allowed cable length is 147 feet.
The cable length mentioned in the standard allows maximum communication speed to occur. If speed is reduced by a factor 2 or 4, the maximum length increases dramatically. Texas Instruments did some practical experiments years ago at different baud rates to test the maximum allowed cable lengths. Keep in mind, that the RS232 standard was originally developed for 20 kbps. By halving the maximum communication speed, the allowed cable length increases a factor ten.
ak
AnalogKid
Jun 10, 2015
2,893
Jun 10, 2015
2,893
Shielding a wire helps prevent the signal being corrupted by radiated interference. For RS-232, usually the cables are not shielded. When they are, eash wire is not shielded separately like audio or video cables. Instead, it is a single shield around the group of individual wires.
https://en.wikipedia.org/wiki/Shielded_cable
ak
ElectronicsR
Mar 23, 2016
72
Mar 23, 2016
72
hello,
how to study or calculate how much capacitance is generated between wires?
ElectronicsR
Mar 23, 2016
72
Mar 23, 2016
72
i have done experiment for capacitor dielectric with mica and air
i dnt understand in air than capicitor was more than mica
ElectronicsR
Mar 23, 2016
72
Mar 23, 2016
72
Hello,
That mean for 10 feet 16*10=160pf??
(*steve*)
25,510
25,510
understand question to ask how phrase sense make a order words sorry I'm can't.
ElectronicsR
Mar 23, 2016
72
Mar 23, 2016
72
why the use of it and there is cu wire with plastic and circular cross wires after that shield...
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
Look up 'coaxial cable' on Wikipedia, it gives a lot of information there and details of the various types of coax.
By circular cross wires, do you mean braiding?
