TX: What does the LOAD, PLATE, & DRIVE knobs actually control?
Discussion in 'Electronic Design' started by billcalley, Apr 8, 2007.
  1. billcalley
    billcalley Guest
    Hi All,
    I know *how* to tune the finals of a "hybrid" HF transceiver, but I
    cannot find schematics of the exact circuits -- or even a good
    explanation -- of exactly *what* components are being tuned inside the
    transceiver itself. With tube transceivers, what exactly does each
    control do? (I.E: the LOAD, PLATE, and DRIVE controls in, lets say, a
    Kenwood TS line). Are these controls attached to the output pie
    network capacitors and inductor of the PA? (Like a "mini"
    transmatch). If so, which control is attached to which component?
    And does anyone know of any drawings or diagrams for this?
    Thanks for any clarifications!
    -Bill
  2. Tom Bruhns
    Tom Bruhns Guest
    Hi Bill,
    This is a better question to ask over in rec.radio.amateur.homebrew or
    the like. But... The drive control most likely tunes the stages that
    supply RF to the power amplifier's grid. The network that couples the
    power amplifier's plate circuit to the RF output connector is almost
    certainly a PI network, with fixed series inductor selected per band,
    but the shunt capacitors at the plate and the output ends are
    variables, labeled PLATE and LOAD (or "LOADING").
    Do a Google search for "Kenwood TS-520S schematic" and you should turn
    up one. You can probably find manuals for others in that line. You
    may find it interesting to simulate the PI network in Spice or RFSim99
    or some similar program.
    Cheers,
    Tom
  3. Tim Wescott
    Tim Wescott Guest
    Plate and load are connected to the final pi network, yes. "Band"
    switches the final coil, among other things.
    Drive controls the tuning of the final grid circuit (and drive tube
    plate). Plate controls the capacitor that's connected (possibly through
    a coupling cap) to the final plate, and load controls the capacitor
    that's attached to the antenna.
    You peak the drive, dip the plate, and adjust load to get the plate
    current you want.
    My TS-520 came with a schematic -- didn't yours?
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Posting from Google? See http://cfaj.freeshell.org/google/
    Do you need to implement control loops in software?
    "Applied Control Theory for Embedded Systems" gives you just what it says.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  4. billcalley
    billcalley Guest
    Thanks Tim, thanks Tom. Your explanations helps a lot, but the
    real TS-520S schems I find on the Web are a little too "real" and
    complex for me. (IE: They are not 'instructional' enough, diagram and
    clarity-wise, for me to really get a very clear idea as to what
    exactly is going on in the PA section).
    Best,
    -Bill
  5. John Fields
    John Fields Guest
  6. MassiveProng
    MassiveProng Guest
    It really is in his best interest. Just getting the answer from
    someone wouldn't do much good.
  7. SFC
    SFC Guest
    Load - antenna coupling/matching
    Plate- tunes the network of the tubes anode
    Drive- tunes the network of the tubes grid
    SFC
  8. billcalley
    billcalley Guest
    Thanks for the great info guys! The exact concept of where the TX
    tuning controls contacted the different parts of the tube circuits is
    what confused me (I'm aware of how matching circuits work). I had
    also looked through the ARRL Handbook (and the Web) before I asked the
    question here, but I did not see a circuit drawing or a satisfying
    description of the answer to my question at all, but maybe I just
    missed it.
    Thanks again,
    -Bill
  9. There are a lot of transmitter schematics on the BAMA website. Some
    complete ham radio manuals, as well.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
