Two TDA1554 on one radiator??
Discussion in 'Electronic Basics' started by Adam Dyga, Nov 22, 2003.
  1. Adam Dyga
    Adam Dyga Guest
    Hello,
    I want to put two TDA1554 amplifiers on one radiator. Can I do that?
    I'm asking, because I don't know if the back metal plane of the integrated
    circuit is connected to internal circuits, and if yes, there can be some
    problems, when I place two TDA1554 on one radiator without isolation.
    Greets
    adeon
  2. CFoley1064
    CFoley1064 Guest
    Hello,
    The datasheet doesn't specifically say anything about case connection, but it
    doesn't say anything about electrical isolation of the case, either. Also, it
    says pins 7 and 11 are connected to "power ground (substrate)". That almost
    always means case/metal tab potential, unless stated otherwise. If you have a
    TDA1554 handy, just ohm it out to be sure. If the case is power ground,
    obviously you should be able to connect two on one heat sink (radiator). If
    you want to be really cautious, wait 'till Monday and call your local Philips
    rep.
    Good luck.
    Chris
  3. Adam Dyga
    Adam Dyga Guest
    I've done this, and the result is that only one pin (output pin) has 7kohm
    resistance to metal tab.
  4. Adam Dyga
    Adam Dyga Guest
    And resistance between 7 or 11 pin to metal tab is about 100ohm, so how do
    you think, can I put two ICs on one radiator??
