Two potentiometers on a pulse width modulator
Discussion in 'General Electronics Discussion' started by Madsalts, Jul 1, 2015.
  1. Madsalts
    Madsalts
    73
    Sep 25, 2014
    I have a pulse width modulator with a dual-ganged potentiometer. I've seen other PWMs with two potentiometers, rather than the single dual-ganged. What two parameters are controlled by the potentiometers? I'm using mine on a trolling motor. If I were to decouple the parameters by using two pots instead of one, what would the effect be? Would this be desirable?
    This isn't a situation where I'd be finding one ideal pulse width and sticking to it. I'd be adjusting this to speed/slow the motor. Thanks.
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,080
    Dec 18, 2013
    My first thoughts are to control the mark and the space durations, but not sure without a circuit diagram. Do you have a circuit diagram or can you link to a similar one.
    Adam
  3. signalman72
    signalman72
    57
    6
    Jan 26, 2014
    Well, it appears that one set is being used as an adjustable voltage divider and the other as an adjustable resister.
  4. Harald Kapp
    10,025
    2,138
    A standard PWM doesn't require two potentiometers - unless you want to control mark and space independently (Adam's post #2), but in this case you'd like to have independent potentiometers, not a coupled one.
    Are you sure the second part of this potentiometer is a potentiometer? There are only 2 wires coming from this part. It could be a switch to completely turn-off the controller in the lowest setting.
  5. signalman72
    signalman72
    57
    6
    Jan 26, 2014
    Ah, that makes more sense! Id nearly forgotten about those switch/pot combos. They were very popular on those little pocket "transistor radios" when I was a kid.
  6. poor mystic
    poor mystic
    1,061
    30
    Apr 8, 2011
    [QUOTE="Are you sure the second part of this potentiometer is a potentiometer? There are only 2 wires coming from this part. It could be a switch to completely turn-off the controller in the lowest setting.[/QUOTE]
    Harald's conjectural switch certainly is in the power supply.
  7. Madsalts
    Madsalts
    73
    Sep 25, 2014
    Thanks for the replies. I'll have to mess around with this. I might decouple the two, since it might be useful to have a killswitch. Furthermore, I can actually find a waterproof pot, whereas I can't find a waterproof dual-gang pot or a waterproof pot/switch combo.
  8. Minder
    Minder
    2,955
    624
    Apr 24, 2015
    I agree, if you look close at the pot rear side, there only appears to be two outer terminals. (switch).
    M.
