Two inputs simultaneously
Discussion in 'General Electronics Discussion' started by oscarbastos, Aug 25, 2014.
  1. oscarbastos
    oscarbastos
    3
    Aug 25, 2014
    [​IMG]
    How can i connect a led to output 1 and 2 and it only power on when the 2 inputs are pressed simultaneously?
  2. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Um and what is the device you are using? Might be helpful to know that first.
    Adam
  3. oscarbastos
    oscarbastos
    3
    Aug 25, 2014
  4. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    You could use an AND gate on the output. You can use a logic gate or make it from a two transistors. Do you really need two LEDs? One LED will tell you the output is on.
    Adam
  5. oscarbastos
    oscarbastos
    3
    Aug 25, 2014
    yes i want to connect the 2 outputs to only one led, how can i make it from 2 transistors?
  6. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Here you go.
    Adam
  7. BobK
    7,682
    1,686
    Assuming the outputs are capable of driving and LED, you can do it with one transistor:
  8. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    Smarty pants :)
  9. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
    Or you can save one resistor by using the transistor as an emitter follower and connecting the collector to one output and the base to the other, with the LED and current limiting resistor between the emitter and 0V. (Need to reduce the resistor to compensate for the base-emitter voltage drop). Bam! He shoots, he scores :)
    Edit: Oops! Foul ball! That circuit would put a diode junction between the two outputs. BobK, I concede defeat :)
  10. Arouse1973
    Arouse1973 Adam
    5,165
    1,087
    Dec 18, 2013
    I removed one doped piece of N type silicon and one resistor :)
    KrisBlueNZ likes this.
  11. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
    Nice one Adam! If a bit of wasted current is not a problem, that's a nice solution!
    Arouse1973 likes this.
