Two 12v inputs switching
Discussion in 'General Electronics Discussion' started by john2k, May 15, 2013.
  1. john2k
    john2k
    183
    3
    Jun 13, 2012
    i have an LED light that's powered by two +12v inputs, one for full brightness and another for dim mode. The two power sources are not on at the same time because i've got an auto relay switching kit that switches off the main one if the secondary power source activates. However, just wondering what I can do as a failsafe in the event that the auto relay switch fails and does not stop the main power and I will end up having two +12v lines active at the same time.
  2. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    Putting a diode in each supply line will stop any backfeed if the supplies are connected together. This will drop about a volt.
    You can connect your relays (with an extra contact) so that when the auxilliary relay is pulled in, the main relay is isolated.
  3. BobK
    7,682
    1,686
    If they are both +12V I don't see how one is bright and the other dim.
  4. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
    What is the problem if both inputs are on at the same time?
    Show us a diagram of how the LED is driven from the two inputs.
    If you're just using two different current limiting resistors, you can modify the circuit slightly (addition of two diodes) to get the behaviour you want, and throw away the relay.
    Show us the circuit diagram first.
