twist sensitive resistor?
Discussion in 'Electronic Basics' started by Dave, Jul 13, 2005.
  1. Dave
    Dave Guest
    I have science project that involves measuring a small torque, or
    twisting force.
    Is there a torque sensitive resistor I can buy? Or perhaps a torque
    sensitive capacitor? I can integrate it into an existing circuit if I
    can find one.
    Thanks, Dave
  2. You could make a capacitor to be torque sensitive. Attach one plate to the
    shaft and the other to a fixed point. The capacity will vary with the
    torque.
  3. Randy Day
    Randy Day Guest
    google 'strain guage' or 'piezo-resistive'.
    HTH
  4. JeffM
    JeffM Guest
    Henry Kolesnik top-posted:
    That will measure angular displacement
    (which may be an analog to torque),
    but it doesn't measure force or radius.
    Please don't top-post.
  5. JeffM
    JeffM Guest
    Next time you post to multiple groups
    http://groups-beta.google.com/group...AALZvBLLWVGyrsYI05cDln-fkJl7JH_CShDXo7kQvHpFA
    post just ONCE
    and put ALL the groups in which you want the question to appear
    on the Groups line.
    This allows EVERYONE who reads the question
    to easily see ALL the solutions that are proposed.
    Henry has already suggested a variable capacitor.
    http://www.google.com/images?q=vari...tormwise+-small_alligator_clips+-amhow+-cb280
    That can be an analog of torque
    (as can a potentiometer--which is smaller and cheaper).
    Both of these will likely require gearing
    to get any kind of resolution
    (leaving you with forward/backward lash).
    A strain gauge measures force (which can also be an analog of torque).
  6. How small is the torque? The magnitude such as between two small,
    balanced and suspended masses and another pair of masses as in the
    Cavendish experiment?
    What is twisting? If it is the famous dumbbell experiment, for
    example, you can just use a simple small-milliwatt 635nm diode laser
    or better yet a HeNe laser and bounce it off of a tiny bit of mirror
    attached to one of the suspended masses. You can easily align the
    beam so that it reflects and then hits an exact point on a distant
    ruler and when the suspended mass shifts slightly through some angle
    X, the reflected beam will go though a deflection change of 2X. This
    may be just fine if you are replicating Cavendish for a science
    project.
    Jon
  7. Jamie
    Jamie Guest
    One of our machines at work has an optical pick up on on
    each end of a drive shaft. when the machine is at idle (no torque)
    the 2 opticals are perfectly aligned or near it. as the shaft starts
    to twist under load, the drive side will get ahead of the output
    side of the shaft thus causing the two opticals to miss align and
    produce an offset of pulses ect./
    also you could simply measure the load current on the drive device?
    there are also things like load cells that use a capactive method.
