twin crystal oscillator
Discussion in 'Electronic Design' started by colin, Apr 18, 2005.
  1. colin
    colin Guest
    while im waiting for my OCXOs to arrive and thinking about what makes one
    OCXO better than others with regard to 1hz phase noise, i thought what if 2
    crystal/amp stages were used for the oscillator, the bandwidth must be
    reduced quite considerably and hence the close in phase noise too.
    not much came up on a search, maybe i will build one and see. i have read
    that very old crystals are better becuase their ageing has settled down to a
    low rate and are the larger size gives better Q.
    Colin =^.^=
  2. Tim Wescott
    Tim Wescott Guest
    I wouldn't try two crystals _in_ an oscillator, but I believe that you
    can get good results by following an oscillator with a crystal filter.
  3. Or there's that circuit, I first saw it in an article by Rohde and
    I thought it was his idea, where you extract the signal from the side
    of the crystal away from the active device. I can't remember the
    circuit, or even if it was special, but he moved the side of the
    crystal that normally was grounded off ground, I think with a
    resistor, and took the signal from there. The crystal was
    then acting as a filter between the oscillator and the rest of
    the world.
    Michael
  4. Tim Wescott
    Tim Wescott Guest
    That would certainly reduce phase noise. If it were me I'd look at
    implementing the best oscillator I could (I'd probably check the Butler
    oscillator for starters). If that weren't enough I'd follow it with a
    filter and accept the inevitable tradeoff between filter bandwidth and
    the difficulty of matching the filter passband with the oscillator
    frequency.
    There is literature out there on low phase noise oscillators, but
    crystal and otherwise.
  5. colin
    colin Guest
    doh, too late done it already, managed to get it working @ 20mhz with 2
    bfe520 transistor inverters stages, would rather use series resonant sc cut
    crystals rather than the at cut parallel resonance mode crystals wich is all
    i seem to be able to get hold of easily. was thinking a 3 stage might be
    better still as the phase needed for each stage would more convenient.
    I figured a second one inside of the loop will be beter than on the outside
    due of the effect of positive feedback, although of course one (or more) on
    the outside is a posibility too. ive not tried it in circuit yet as i need
    to make a second one, also the colector waveform has a weird kink in it
    almost like its trying to oscillate at 2nd harmonic (wich it shldnt) but i
    need to multiply it anyway. (and the ocxos have turned up now too :)
    Ive seen the circuit refered to in a couple of places, ideal if you need a
    clean sinewave. there are many low phase noise circuits out there wich apear
    to be as good as the (single) crystal used.
    my circuit feedback is similar in nature to a butler type.
    Colin. =^.^=
