TVS Transient Voltage Suppressor
Discussion in 'Datasheets, Manuals and Component Identification' started by bob.steel, Mar 1, 2020.
  1. bob.steel
    bob.steel
    14
    Feb 27, 2020
    This device given a part number of say '1.5KE350' I have not used before .
    I understand it to be just a zener diode in fact but it won't conduct until it reaches 1.5K volts ,is that right? Its noted as 350 amps so I'm confused . Does it only conduct if the voltage goes over 1.5K v or does it only conduct if the current goes over 350 amps?
  2. bertus
    bertus
    348
    112
    Nov 8, 2019
    hevans1944 likes this.
  3. Harald Kapp
    9,669
    2,020
    This is kind of a zener diode called transient voltage suppressor diode (short TVS). It is not meant to be operated permanently in the zener region but only during short pulses of overvoltage to protect equipment.
    hevans1944 and bertus like this.
  4. bob.steel
    bob.steel
    14
    Feb 27, 2020
    But "Does it only conduct if the voltage goes over 1.5K v or does it only conduct if the current goes over 350 amps?"
  5. Bluejets
    Bluejets
    3,791
    783
    Oct 5, 2014
    Neither...both are maximum ratings of the diode.
  6. bob.steel
    bob.steel
    14
    Feb 27, 2020
    You know I would just like a straightforward answer . I know how a zener works.
    Does the diode conduct ONLY when the voltage spike passes 1.5Kv ?
    Does the diode conduct ONLY the equivalent of 1500 watts ? So if the voltage were 1.5Kv the current passed would be 1 amp only any more and it would blow ?
    Or can the zenner conduct at some lower voltage and pass more current .
    C'mon don't be shy , don't send me off somewhere else to read or watch ,take a stab at a simple explanation yourself . That's why I'm asking here.
    Edit - Whoops Bertus ,Thanks, . does that mean its conducting voltage is 350V? and 4.3 amps can pass?
  7. Bluejets
    Bluejets
    3,791
    783
    Oct 5, 2014
    First thing came up on Google search.....amazing...
    bertus likes this.
