F
frank
Hi all,
this little TV set (14" by philips, more than 20 years old) started some
months ago to hiss, it was mainly a little EHT leakage from the junction
between the LOPT and the ultor cable. It was annoying but my parents
didn't care at the time (I'm not a TV user). It had no other visible
symptoms, so I think the line final transistor (little BU508) was
holding well. Since some days, the EHT started to spark violently from
the cable to ultor junction and the set was shutting down, so I couldn't
ignore the problem anymore, my parents want to watch the TV!
I opened the set, cleaned 20 years of dust, redo many solder joints that
were just looking suspicious, put an heavy amount of epoxy in the
leaking junction on the EHT transformer and some teflon band over the
epoxy and did the same on the cable to suction cup junction.
I also checked the +125V line (this is primary supply on the output
transformer that then goes to the BU508 collector) and it was well in
specs, however lowered to 124.6V which is still in specs and gives a
little less EHT.
Ok, all this effort cured the leakage over the transformer but after a
good amount of epoxy, the juntion near the ultor cup was still sparking
(this started again after one day from the first "cure"). I re-opened
the set and put a good amount of hot glue over the epoxy and it's
holding again now.
It's normal for 25 kV to jump over some 4-5 mm of epoxy or I'd better
check if the EHT is way over its normal value for this set? Yes, I have
a 1000:1 probe but I never used it on a TV set, it's just for
oscilloscope repairs (where voltages are much less than that). Also I
can't really see any other malfunction on the set, so I wonder....
Any expert out here? How do you measure the EHT on a TV set exactly (if
this is something doable in the first place)?
TIA
Francesco IZ8DWF (who watches tv only from the back of the set and not
very often)
little less EHT.
holding again now.
TIA
very often)
