news.verizon.net said:
A friend of mine gave me an old 27 inch TV that no longer works. Upon
inspection of the insides, I noticed the "5A 125V GMA" fuse was blown. I
purchased a 10 pack of these fuses, and when I replaced it the fuse blew as
soon as the TV was plugged in again. I am assuming that there is a short
circuit on the board somewhere. How would I go about finding the short?
Is it possible the power cable or its connection to the circuit board is
related to this short?
Thanks in advance.
Does the set have a 'conventional' mechanical on / off switch as well as a
standby switch ? If so, does the fuse blow when this switch is set to off ?
If yes, you might have a short circuit noise filtering cap across the
switch. If the fuse only blows when the main power switch is on, then it
gets a bit more complicated. It could still be a noise filtering cap on the
'back' side of the switch. It could also be a faulty posistor, which was
quite common on a lot of sets for violent fuse blowing. However, if it's
none of those things, it gets a lot more complicated as, if the set is
anything up to say 10 years or so old, it will employ a switch mode power
supply. These are dangerous to inexperienced hands, and notoriously fickle
with their faults. Violent 'instant' fuse blowing is usually down to a short
circuit chopper transistor or hybrid, or sometimes the bridge rectifier, but
that is often not the end of the story. There may be assorted damaged
resistors, diodes, control IC if it uses one, feedback opto, and the whole
lot may have been caused in the first place by a faulty electrolytic in the
primary side.
If the fuse does not blow instantly (ie set needs to be taken out of
standby) or violently, then the chances are that the fault is downstream of
the power supply, most likely in the HOP stage somewhere. However, when this
is the case, most well designed switchers will detect the excess load, and
shut down to a 'safe' mode where they will squeal, tick or chuff, rather
than blow fuses. A bit more info is needed really, before any 'reasoned'
diagnoses can be made.
Arfa
