TV to VGA converter
Discussion in 'Hobby Electronics' started by KoRRupT, Jan 19, 2004.
  1. KoRRupT
    KoRRupT Guest
    I'm have a S-video source (digital TV decoder box) and would like to display
    it on a 19" CRT monitor. Is there a device which I can buy that allows me to
    do this? I know you can get VGA->TV converts,... but never really seen one
    that goes the other way....
    Cheers!!
  2. eltan
    eltan Guest
  3. Phil Allison
    Phil Allison Guest
    "KoRRupT" <[email protected]
    ** A new 19 inch ( 48 cm) TV set will cost you less than the box of
    tricks to do that.
    .......... Phil
  4. amstereo
    amstereo Guest
    standalone units sell for ~$200 Brillient stuff. :)
  5. Leon.
    Leon. Guest
    something like this ?
    http://tinyurl.com/2f4q9
  6. Leon.
    Leon. Guest
    even better
    http://tinyurl.com/39ggc
  7. KoRRupT
    KoRRupT Guest
    | tricks to do that.
    Thanks Phil,.. it may be cheaper with a 2nd TV set... but I don't have that
    much room and using the PC monitor seems to be a logical idea...
  8. KoRRupT
    KoRRupT Guest
    Cheer's Leon... that looks perfect.... a bit pricey, but exactly what I'm
    after.
  9. KoRRupT
    KoRRupT Guest
    | Yes, check out mpeg decoder card or aka "Capture card".
    | Here is the link http://www.swann.com.au/products/dv/easy/dvd_easy.htm
    | probably cost around $200 or more
    Not quite what I'm after... I want to use the PC Monitor without powering up
    the PC... Thanks anyways!
  10. Phil Allison
    Phil Allison Guest
    ** Huh ???
    Since when is a a 19 inch TV necessarily bigger than a 19 inch monitor
    ............. Phil
  11. Rod Speed
    Rod Speed Guest
    He likely needs the monitor for the PC anyway, stupid.
    So being able to watch TV on it saves on one screen, stupid.
    No wonder you're completely unemployable.
  12. Phil Allison
    Phil Allison Guest
    "Rod Speed" <
    ** Then explain why he rejected the obvious idea a using a video card in the
    PC ???
    Only the OP knows his reasons - you fucking don't.
    .............. Phil
  13. Rod Speed
    Rod Speed Guest
    He said he doesnt want to have the PC on when watching TV, stupid.
  14. Phil Allison
    Phil Allison Guest
    ** No he did not.
    ............ Phil
  15. Rod Speed
    Rod Speed Guest
    Not a fucking clue to its name, as always.
  16. KoRRupT
    KoRRupT Guest
    | > that
    | > ** Huh ???
    monitor
    Phil
    Rod is correct. I still want to be able to watch TV *and* use the PC. Since
    my room is only a little bit bigger than a closet, it'll be convenient to
    use the PC Monitor as a TV without having to turn the PC on.
    BTW I found exactly what I wanted. Here's the link if anyone else is
    interested: http://www.highway.net.au/parts/converters/1324.html
  17. Phil Allison
    Phil Allison Guest
    "Rod Speed"
    ** No he did not !!!
    Go get fucked you masturbating Robot.
    ....... Phil
  18. Phil Allison
    Phil Allison Guest
    ** No he was not - read his next post.
    ** Opposite to Rod's next post.
    ** That remark makes no sense.
    How does operating the PC's on switch lose space in your room ???????
    Your way means having to unplug the monitor lead from the PC *every time*
    you need to watch TV and then put it back to use the PC - that seems
    MASSIVELY inconvenient.
    Using a video capture card mean you have one or the other any time or can
    even have both at once ( ie the TV image in a window) .
    .............. Phil
  19. You'll still need an RF tuner to use with that, a cheap VCR would
    probably be the go.
    Regards
    Dave :)
  20. Phil Allison
    Phil Allison Guest
    ** In his first post the OP said:
    " I have a S-video source (digital TV decoder box) and would like to
    display
    it on a 19" CRT monitor. "
    Do try reading the whole thread - David.
    ............. Phil
