TV shows stripes/lines at the top of the screen
Discussion in 'Electronic Basics' started by -Almazick-, Jun 11, 2006.
  1. -Almazick-
    -Almazick- Guest
    Hello!
    I have Panasonic TV about 1 year old. It was working great til a few weeks
    ago, now it shows stripes/lines at the top of the screen that used to get
    better after tv was getting warm. Now I got more stripes/lines at the top of
    the screen and they don't dissapear even when tv gets warm. I removed the tv
    rear cover and found only 2 knobs for Focus and Screen and they won't solve
    the problem. I tried to adjust Var Resistor and again nothing. What can I
    do? What should I check for? Please help.
    Almazick
    www.tvnorthshore.com
  2. Jasen Betts
    Jasen Betts Guest
    "about one year old": check your warranty.
    Bye.
    Jasen
  3. Bad power supply filter capacitor. Replace if the set is not unde
    warrantee..
  4. -Almazick-
    -Almazick- Guest
    problem solved
  5. Art
    Art Guest
    Have the vertical circuitry repaired.
  6. -Almazick-
    -Almazick- Guest
    I had to replace the capacitor in vertical def. output
  7. BJ
    BJ Guest
    Usually the vertical hold transistor, roughly $5 - $20 AUD so I hope the
    warranty worked for you...
