HellasTechn
- Apr 14, 2013
- 1,579
- Joined
- Apr 14, 2013
- Messages
- 1,579
Hello friends,
I am looking at this Samsung LE32B450C4W television that would blow the PSU main fuse when connected to MAINS.
I found the bridge rectifier Shorted and a blown mosfet (QP802s K10A60) i replaced both (actually the K10A60 with a K15A60) and the mainboard comes on. I hear the startup sound but the backlight does not come on at all, not even for a second.
A friend of mine tv lend me a PSU from the same tv model and so my samsung worked all right. So i know ccfl lamps are ok and that something else is wrong with my PSU. i have measured all capacitors and transistors (heat sink mounted) also i replaced the sem2006 but nothing changed.
Any advice ?
thank you so much !
Any advice ?
thank you so much !
