TV problem - buzzing
Discussion in 'Electronic Repair' started by Chaos Master, Sep 24, 2003.
  1. Chaos Master
    Chaos Master Guest
    I have a very very old Toshiba TV that has a problem: There's an irritating buzz
    coming from the TV. When I switch channels, the buzz disappears for a while,
    then reappears. Volume control has no effect.
    The TV is old (circa 1980), so many could say "throw it away", but it's a good
    TV (the only way to tune it, manual tuning, allows very precise adjustment -
    auto tuning is not 100% perfect in Brazil).
    Anybody here knows the cause of this problem?
  2. TV Fixer1
    TV Fixer1 Guest
    Possibly the Deflection Yoke has a loose magnet inside it; very difficult to
    repair if you're not familiar with TV innards.
  3. Nigel
    Nigel Guest
    buzz
    good
    What is the model & chassis number ?
    What tests and/or work have you done on the set so far ?
    Are you using it with any other equipment, e.g. VCR or Satellite receiver ?
    Not enough useful information in your posting for anyone to make
    suggestions.
  4. Chaos Master
    Chaos Master Guest
    TV Fixer1 scribbled:
    OK. I'll take a look.
