TV Philips G112 chassis pincushion problem
Discussion in 'Electronic Repair' started by Freddy T, Nov 26, 2003.
  1. Freddy T
    Freddy T Guest
    I have a Philips TV , it's a G112 chassis with rather curved looking
    vertical lines at each end, pincushion . So I though it was the E/W
    circuitry, you know the vertical modulated onto the horizontal stuff. But
    it all checks out okay. Can anyone kindy offer any help?
    I think the model number is a 29sp1798
    Thanks for any help in advance
    Frredy T
  2. Jerry G.
    Jerry G. Guest
    How did you determine that E/W circuitry is working correctly? If it is
    working correctly the E/W pin should come in.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    Frredy T
  3. Freddy T
    Freddy T Guest
    I disconnected the main transistor in the E/W cctry and got a bowed in
    picture with the deflection stopping along the edges of the bow. When I
    restored the transistor I got a full screen but any vertical lines close to
    any edge where bowed inwards, ( my original problem). I also tested both
    transistors and measured all the components in the E/W circuitry,
    includings caps for value and also ESR value on the electros.
    Freddy t
  4. mo
    mo Guest
    Try removing coil 5933
    measure the resistance
    should be about 5 Ohms (1 Ohm is short - Replace)
    Good Luck,
    --- mo ---
  5. Freddy T
    Freddy T Guest
    Thanks mo
    Unfortunately I had taken that coil out and did a ring test and it came
    up okay. But I took it out again after seeing your advice and blast it
    measured 5 Ohms.
    I may have to start removing more of those pesky surface mount
    components in the E/W cctry. Arrgh what a pain.
    I wonder if there is a fault elsewhere that can show up as an E/W
    problem? I am not sure if I should continue working in the E/W area or
    maybe look elsewhere?
    Thanks for any help
    Freddy T
  6. GPG
    GPG Guest
    Is the bow the same with and without e/w? If so, missing sawtooth from vert o/p
  7. Freddy T
    Freddy T Guest
    Thanks GPG.
    I ended up finding my problem. Leaky vertical caps had caused the vertical
    feed to the E/W to go high. Some signal was getting thro but not much.
    Replaced the vertical caps and fixed the connection to the E/W and all
    works.
    Thanks for everyones help.
    Freddy T
