L
L.Chung
After replacing the HOT and doing power up check, its usual to put in
series a lamp bulb to limit the current. The problem comes after the
lamp bulb is removed and full working voltage is fed to the circuit.
There is the possibility of HOT damaged instantly via HV secondary
breakdown if there is some remaining fault in the rest of the circuit.
As I understand from surfing the net, the HOT is usually operates at
some 80% of its highest breakdown voltage Vceo.
I was wondering is it possible to put in parallel a string of
varistors (or a series of neon bulbs with voltage grading resistors)
from HOT collector to 0V so as to act as HV protection during the
final test. After the max. coillector flyback pulse amplitute have
been measured and confirmed using a 100:1 probe, the varistors can be
removed.
In addition, if I can build a device which impose a fixed(settable)
voltage drop with current limit, would it be possible to use it in
series with the horizontal B+ to bring up the voltage to the Horiz.
stage gradually?
Thanks in advance for your reply.
Regards
L.Chung
removed.
stage gradually?
Regards
L.Chung
