TV Color charts
Discussion in 'Hobby Electronics' started by AJD, Jul 17, 2003.
  1. AJD
    AJD Guest
    Can someone suggest a site that has PAL color charts and good info on
    how to adjust a PAL TV set for correct color, contrast etc?
    AJD
  2. David Sauer
    David Sauer Guest
    Go buy a test DVD. There should be a pal version available by now.
  3. Phil Allison
    Phil Allison Guest
    ** The procedure involves a special test lamp with the correct whiteness
    or colour temperature.
    One matches a white screen to the lamp.
    No colour blind people need apply.
    Contrast and brightness are set to suit ambient light conditions
    and taste.
    ........... Phil
  4. Steve
    Steve Guest
    Or in our case, a rather expensive Philips PM5639 colour analyser and
    pluge, colour bars and 15% and 85% white test signals. We also need
    to be able to disable the red and green guns for correct black level
    adjustment as per our procedure.
    Depends how crazy you wanna go I guess, but it would seem difficult
    without one of the above mentioned devices.
    ABC canberra has such a reference lamp, but we have used it in the
    past and found it to be a pain in the backside. Not to mention the
    strain on the ol' retina. But if you're only doing one screen that
    wouldn't be too bad.
