TV broke ?
Discussion in 'Electronic Repair' started by Mr Funk, Nov 1, 2004.
  1. Mr Funk
    Mr Funk Guest
    How do I get rid of the vertikal linze on my TV skreen ?
  2. Franc Zabkar
    Franc Zabkar Guest
    Turn it on its side.
    - Franc Zabkar
  3. good one Franc
  4. Art
    Art Guest
    White out??
  5. Eric
    Eric Guest
    Have you turned the brightness down?
    - Franc Zabkar
  6. Sofie
    Sofie Guest
    Turn it OFF and UNPLUG it from the AC power.
  7. hemyd
    hemyd Guest
    Has he tried another channel? Perhaps this channel is transmitting a
    vertical line.....
    Henry
    Australia
  8. NSM
    NSM Guest
    | vertical line.....
    Watching "The Outer Limits"?
    “There is nothing wrong with your television set. Do not attempt to adjust
    the picture. We are controlling the transmission. If we wish to make it
    louder, we will bring up the volume. If we wish to make it softer, we will
    tune it to a whisper. We will control the horizontal. We will control the
    vertical. We can roll the image; make it flutter. We can change the focus to
    a soft blur or sharpen it to crystal clarity. For the next hour, sit quietly
    and we will control all that you see and hear. We repeat: there is nothing
    wrong with your television set. You are about to participate in a great
    adventure. You are about to experience the awe and mystery which reaches
    from the inner mind to the Outer Limits.”
    N
  9. Pedro
    Pedro Guest
    A common fault is dried out decoupling electro for the 100~250 volt
    supply line from LOPT feeding RGB transistors on the neckboard.
    Another scenario is ringing, also caused by dried electro(s).
    Pedro
  10. Franc Zabkar
    Franc Zabkar Guest
    Maybe he's watching the VCR test channel.
    - Franc Zabkar
