Turning on an AT Power supply?
Discussion in 'Electronic Basics' started by www.ChantCd.com, Jul 23, 2004.
  1. (I was trying to use an ATX supply before, but it seemed more complicated,
    so...)
    There is a switch on this AT-style power supply that I have now (of course).
    I stripped off the ends of one of the hard drive connectors, making sure
    they
    don't touch when I hit the power switch.
    I hit the switch, and nothing happens.
    Do I have a bad power supply? Or do you have to have a load of some kind for
    it to work? I'm just trying to turn it on with nothing - so I can measure
    the voltage
    with a VOM. Starting at the beginning, as it were.
    The other day, I was diagnosing a friend's bad PC - it turned out to be a
    bad power supply. (ATX)
    The way I found out? I just plugged the AT power supply to the hard drive
    (which wasn't spinning up, BTW) and turned it on - voila! The hard drive
    spun up. By this I guessed that the power supply was bad (turned out to be
    the case).
    My point is, I had just 1 hard drive as a load, and the thing powered up
    just fine.
    (I'm pretty sure it's the same power supply, too)
    Matthew
  2. Puckdropper
    Puckdropper Guest
    You have to have a load. If the power supply detects no load, it shuts off.
    Puckdropper
  3. Do you know how much of a load? Would 50 mA be enough?
    Matthew
  4. Puckdropper
    Puckdropper Guest
    I normally use a floppy drive or some other computer component. I
    suppose you'll have to just try it and see.
    Puckdropper
  5. I tried a hard drive, and it USUALLY worked well - but the results were
    erratic. A few times it would shut off after 10 seconds, other times it
    would sound odd like the HD wasn't getting enough power - yet it stayed on.
    I'm thinking of adding another hard drive (maybe a 100 MB which I can get
    for free)
    Matthew
