S
Steve
Looking for a circuit to turn off normally on negative 500 volts with
logic high TTL. The negative voltage would be normally on with TTL
low or with no control signal being applied. A high TTL would turn
off the negative voltage (off period will be perhaps 100
microseconds). The negative voltage is applied to plates in a vacuum
so very little or no current draw. Turn off/on times of tens of
microseconds. It would be ok to use a battery for bias if necessary.
Steve
Steve
