Tuner Module Philips UV914
Discussion in 'Beginner Electronics' started by Hansjörg, Jun 27, 2010.
  1. Hansjörg
    Hansjörg Guest
    I'm looking for datasheets for the Philips tuner module UV914. Has someone
    information how to use it? (Pinout, frequency select)
    Hansjoerg
  2. Mike G
    Mike G Guest
    I was looking for exactly the same thing!....did you ever locate it?
    Mike.... W2AIQ
  3. Joerg
    Joerg Guest
    Hans-Joerg had asked the same question in a German NG and received a
    couple of responses there. The link I gave him is for the SF914,
    possibly the same tuner (sometimes there are minor frequency range
    variations):
    http://www.vandijkenelektronica.nl/preview.php?index=753&table=files
    Another poster found an instruction how to do a project with the UV916
    which might also be helpful:
    http://hem.passagen.se/communication/uv916rec.html
  4. Mike G
    Mike G Guest
    thank you very much for the info!
    Mike, W2AIQ
  5. Joerg
    Joerg Guest
    You are welcome. If you want to exchange ideas about using the tuner I
    think Hans-Joerg can be reached at:
    m26872 the-at-sign access.uzh dot-sign ch
