Tube VHF power stage
Discussion in 'Electronic Design' started by Claus Jensen, May 17, 2007.
  1. Claus Jensen
    Claus Jensen Guest
    Can anyone tell me where to find, or start looking for, a relatively
    modern one or two stage vacuum tube power amp that I can feed with a
    standard lab VHF generator. 15-20W output would be sufficient. Prefer
    single ended and lowest practical B+.
    Claus Jensen
  2. Tim Wescott
    Tim Wescott Guest
    Why?
    Vacuum tube power stages make lots of sense when you get too big for a
    couple of transistors; they're the bee's knees if you want to go above a
    kilowatt or so.
    But 20W is well within the capability of a beefy transistor stage. What
    do you perceive as being so special about a tube amp?
    Tim Wescott
    Wescott Design Services
    http://www.wescottdesign.com
    Posting from Google? See http://cfaj.freeshell.org/google/
    Do you need to implement control loops in software?
    "Applied Control Theory for Embedded Systems" gives you just what it says.
    See details at http://www.wescottdesign.com/actfes/actfes.html
  3. Claus Jensen
    Claus Jensen Guest
    In this case, I am interested in the higher output impedance tubes
    present. I would prefer not to use a matching network.
    Claus
  4. joseph2k
    joseph2k Guest
    Just some questions. How much does your generator output? What is the
    bandwidth of the desired amplifier (30 MHz to 300 MHz)? Why tubes, solid
    state can do up to 1 kW even at 30 Mhz to 300 MHz. Please provide enough
    information to make reasonable design choices.
  5. joseph2k
    joseph2k Guest
    Tubes in that power and frequency range have Rp of several hundreds to some
    thousands of ohms. Transistors are much closer to 50 ohms (Rc or Rd) in
    that power range, especially some higher than needed power FET's
