P
powerampfreak
Hi all,
Me and a friend at work argue about the behaviour of a simple tube
preamp stage found in most guitar amp front ends. I know I'm right but
he says he's right. Well, here we go:
Imagine a standard circuit with 100kohms anode resistor and 1.5kohms
cathode resistor. The tube is a standard ECC83 (12AX7). Across the
1.5k resistor a 1u cap is in parallell.
In my eyes this will introduce a slope at around 100hz (1/2piRC)
simply limiting low frequencies.
My friend (former...) says that changing the 1U cap to a 50u cap will
increase gain. This is true, but this also affects the low frequency
gain of the stage. Instead of 100Hz, it will go down to around 2Hz.
But my opponent says this is not true.
I'm not used to tube circuits, just transistors stages, but I know the
above applies to transistor stages.
So, would anyone just tell me I'm right in my point?
Regards,
PAF
Regards,
PAF
