Sampei said:
I found a sylavania 6AQ5A tube and i want to build a tube guitar amp
with this electronic tube.Anyone has a link or a schematic?
Thanks in advance
A single 6AQ5 is not a suitible choice for a guitar amp. Two 6AQ5's in push
pull can be used to make a class AB1 amp of about 10 Watts power output.
This is quite feeble for a guitar amp. Of course you will need an
appropriate output transformer and a power supply giving 250 Volts at 70mA.
Furthermore you'll have to get the tubes and parts for the front end and
phase splitter, 12AX7 and 12AU7 or something similar.
If you are serious about it, consider two EL34' tubes for the output stage
and don't screw around with 6AQ5's. The amount of work is nearly the same
and when you are through you'll have a much better amp.
