B
Bjarni Juliusson
Hi everybody.
I was building a little circuit out of scrap TTL logic I had lying
around, when I needed a small amount of RAM. I found a 1K chip
apparently manufactured in 1974, and figured it was probably TTL. At
first it worked fine, but I soon noticed the data output would flicker
when the addresses changed. I touched the chip, and it flickered some
more. I suppose the problem is marginal input levels. A googling
revealed that the chip (a 2102) is in fact NMOS, not TTL as I first had
thought. Because I'm still learning this stuff, my question is: how do I
properly interface this NMOS device to the TTL devices making up the
rest of the circuit? Do I pull up? In that case, what values are
appropriate? Any help greatly appreciated.
Bjarni
Bjarni
