pistolpedro
- Jun 3, 2013
- 6
- Joined
- Jun 3, 2013
- Messages
- 6
Hello this is my first post in this forum. this place have helped me repair a couple of things.
but now i need a little help.
After a power surge the printer stopped working, so i took out the adaptor and started testing the leads but i am not getting any readings.
The printer is a canon mp600r. it was quite expensive so i would like to repair it.
so i open it and found there is 3 fuses, one is blown.
i exchanged the blown fuse with a new one but it also blew.
There must be a faulty component causing this to happen.
I have traced the fuse connections and i am ready to measure every component to find the fault and learn some things in the process.
3 big diodes makes me confused, they are the following with the measurement result:
D9: 31DQ/06/7L Reads .200
D10A: 3PHA/20/7D Reads .256
D10B: 3PHA/20/7D Reads .257
I have THIS tester: http://www.ebay.com/itm/TRANSISTOR-...399&pid=100033&prg=1011&rk=1&sd=190821060462&
acording to that tester the diodes are faulty. is it correct? or it is special diodes that gives such readings?
secondly i am confused with the mosfet k3562. i need help to figure out a way to test it. i have made a lab bench power supply from an old atx computer power supply that i can use to test the mosfet with a little guidance.
I have tested it with the multi tester i buy from ebay and i will attach that too.
i will attach pictures of board and keep all of you updated.
thanks for any help i might get!
