Trying to make usb-hub
Discussion in 'Sensors and Actuators' started by desasteur, Feb 6, 2021.
  1. desasteur
    desasteur
    3
    Feb 6, 2021
    Hey everybody, I'm trying to learn IC and I'm not really good...
    But I just made usb-hub (with led) that is connected to a laptop by usb c, and I wanted to know what I did wrong.
    Thanks !
  2. Harald Kapp
    11,978
    2,806
    What are the problems you have? More detail, please.
  3. desasteur
    desasteur
    3
    Feb 6, 2021
    Of course, it's my first circuit and and I'm not sure it work well, I would like to know if I made something wrong, like badly use a pin of the gl850g, or no protection against current, bad optimisation of data transfer,...
    It's to print a good, working pcb and learn of my mistakes
  4. bertus
    bertus Moderator
    2,267
    841
    Nov 8, 2019
    Hello,
    I have made some remarks on your schematic, that are not clear:
    I found the V33, it is COMING from the GL850 pin 24.
    The label shows an incoming signal at the GL850.
    Please correct ALL labels to have a correct schematic.
    Bertus
  5. bertus
    bertus Moderator
    2,267
    841
    Nov 8, 2019
    Hello,
    The GL850G has input , output and bi-directional signals.
    Bertus
  6. desasteur
    desasteur
    3
    Feb 6, 2021
    Hello, thank you very much for helping me, I tried to make a circuit as simplest as possible, so I removed reset pin (I didn't fund it was necessary in datasheet) and I used clear labels, do you think it's better like that ?
