Im trying to copy this LED Blinker.
http://cappels.org/dproj/simplest_LED_flasher/Simplest_LED_Flasher_Circuit.html
But I cant get it to work even tho I think I have everything connected together properly.
Im using two 9v batteries connected together so 18v total... but I think my problem might be because there is too much voltage?
When I connect everything together the LED lights up and stays on but doesn't blink.
This is from the website
"If the resistor that charges the capacitor is too low in value (or if the power supply voltage is too high), the current through the transistor will not become low enough for the transistor to turn off. If the resistor that charges the capacitor is too high in value (or the power supply voltage is too low), the capacitor will not be able to charge to a high enough voltage to enable the transistor to turn on. This is because the transistor draws as small amount of current before switching on."
Could the problem be as simple as there being too much voltage? I tried various resistors, I tried only using only 9v but then when I do that it doesn't even light up... and when I use 18v it stays lighted up.
