Ice Coffee
- Feb 21, 2010
- 4
- Joined
- Feb 21, 2010
- Messages
- 4
I am trying to combine 2 video signals using a 50/50 vertical split, I will try to elaborate.
Signal A [_|X]
Signal B [X|_]
Combined Output signal [_|_]
as you can see I have cropped off the right half of Signal A (represented by the X) and the left half Signal B and then combined the 2 to make the resulting output signal.
So far I have worked out I can do half of it using a dac decoder chip, infact this
TVP5150AM1 from texas instruments has an AVID feature the will allow me to crop each picture to the 50% I need, I will then need an adc encoder chip as the resulting signal from dac is in Y,cb,cr digital format, but combining the 2 images into one is not clear to me ! if the sync pulses were tied together I could use some fast video switching to switch between the two resulting images without any tearing, but that sounds like a cheap hack to me, any input is much appreciated.
Thanks in advance
Ice
Signal A [_|X]
Signal B [X|_]
Thanks in advance
Ice
