Trying to build a timer switch
Discussion in 'General Electronics Discussion' started by Steven L Coulombe, Feb 11, 2016.
  1. Steven L Coulombe
    Steven L Coulombe
    Feb 11, 2016
    I'm looking to build a timer for my science class that needs to be quite accurate. I'd like it to start as an object is released, and stopped again once it stops. I want to be able to calculate average speed. I have no idea what components I would need to accomplish this. Buying one would be easier, but I don't even know what to search for.
  2. Sadlercomfort
    Sadlercomfort Ash
    424
    55
    Feb 9, 2013
    Average Speed = Total Distance / Time
    If you are trying to measure falling objects you will find they all fall at the same rate.
    Are you trying to measure the speed of an object which travels along a surface?
  3. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    "If you are trying to measure falling objects you will find they all fall at the same rate."
    Only in a vacuum! ;)
    Ken
    davenn likes this.
  4. Sadlercomfort
    Sadlercomfort Ash
    424
    55
    Feb 9, 2013
    Of course :rolleyes: Still the velocity difference would be negligible, unless dropping two objects from a great hieght or having a large difference in surface area in the objects.
  5. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    Steven,
    If you want to buy one, Google: photogate
    There are commercial ones like: http://www.novatech-usa.com/Products/Mechanics-Educational/DTPHG1?gclid=CIC4q_HW8MoCFdcYgQod4nAOoQ
    I've used cheap stopwatches to time periods. Used LEDs or laser pointers and a photo transistors to detect the start and stop events. Photo transistor drives a MOSFET. The is MOSFET placed across the stopwatch's start-start switch contacts. How accurate do you need the time to be? I think stopwatches are good to 100th of a second. But this requires some electronics skill.
    Ken
