BarNash said:
Hi all
Is there a way to implement a true random number generator with logic gates
,nand nor FF etc without using white noise from a zener diode for example?
BarNash
I made a pseudorandom noise generator for audio testing with a
microprocessor based 32 bit two tap shift register. The processor is a
PIC16F676.
The generator operates on a 4 MHz internal clock with a 77kHz chip rate. It
produces a white noise sequence that is pseudorandom, not actually true
random which is not possible in this kind of digital system.
Connected to the processor output is an RC network to convert the white
noise sequence into "pink" noise for audio work.
If you are interested, I can give you the code and other details. Email me
for details: nsmontassocatyahoodotcom. Remove the ns from the address start.
