Hi, I am currently in the process of rewireing a truck. The only factory pieces I'm reusing is the lights and the switches. I figured out what wires I need to use for the switches a ran all the wireing and I went to test it and everything worked as it should except the brake lights. All the running lights worked as they should and the turn signals worked. I traced the problem for the brakes to a broken wire. Once I repaired it all the lights worked fine as long as the brakes were off. As soon as you hit the brakes the front running lights come on and the turn signals do not flash. But as soon as you let off the brakes everything works as it should. So my question is do I need to put a diode on the brake lights to keep them from back feeding to the rest of the lights? If so what kind of diode should I get and were exactly should I put it?
Jordan
Jordan
