Troubleshooting
Discussion in 'Electronic Design' started by Herbert Blenner, Aug 29, 2006.
  1. The following wave file contains a voice with a peculiar distortion.
    http://www.members.aol.com/hdblenner/doyouwant.wav
    I have viewed an oscillogram of the waveform and based upon the
    asymmetry conclude that failure of one stage of a push-pull audio
    amplifier caused of the distortion.
    I would appreciate any comments and especially welcome further
    analysis.
    TIA
  2. A single-ended bipolar transistor stage with no standing current will
    also produce this sort of sound. It's half-wave rectified, somewhat
    biased off.
  3. I agreed that improper design of a single-ended stage would cause
    distortion.
    However, an earlier portion produced by the same equipment contains a
    mid sentence transition from symmetrical to asymmetrical audio
    accompanied by a loss of volume.
    http://www.members.aol.com/hdblenner/trackseven0636.wav
    Herbert
  4. ehsjr
    ehsjr Guest
    So people are supposed to play guessing games while you
    slowly dole out pertinent facts you have but hide from them?
  5. Travel Lightly and Swiftly: If all you carry is a hammer, the all your
    problems become nails and then they can all be solved by percussive
    maintenance (preferable preemptive).
