P
phaeton
Hello!
Thanks to everyone who gave me help a few weeks ago regarding the bass
amplifier that was doused in soda. I ended up running the circuit
board under warm water in the sink, and rinsing it off with distilled
water afterwards. It cleaned right up with no hard water deposits.
However, while it seems to work better than its description, it's
still got some issues (surprise, i know). It still has a problem
where the volume level will fluctuate upon its own whim. There seems
to be two different symptoms, which could be two different situations:
1) Usually when it is first started up, the volume level is very weak,
and distorted. It almost sounds as if there is a transistor or opamp
misbiased. Then, it will suddenly correct itself. The sound level
comes up to where it is supposed to be, and it plays/sounds fine.
Sometimes it will be alright for half an hour, sometimes it will act
up again.
2) Sometimes the volume level just drops, with no distortion. It
doesn't act like a dirty pot, either, as I can turn the volume up and
down, and it follows it perfectly, it's just as if it is running a
huge powerbrake. In my experience, dirty pots can make the volume
fluctuate, but usually a small turn of the pot will move the wiper off
of whatever piece of crud it is on and it restores to its proper
volume level. This is different.
Looking at the schematic, I don't see any bias adjustment points.
Things are pretty much fixed, and that still wouldn't solve whatever
condition is changing things up. My first thought is then maybe the
power supply could be acting up, but I'm not sure what sort of event
would cause that, or how to measure it (aside from hooking my DVOM up
to +57V and -57V and seeing if it fluctuates from ~114V over time).
My next thought is to probe the pins of all the opamps and transistors
to see if their levels are reasonable, and/or change when it acts up.
If anyone could throw me a bone, that would be appreciated. I won't
expect someone to walk me through testing a live circuit they've never
seen before, but I'd appreciate any help or pointers. I know that
this post qualifies for the canonical "if you have to ask these
questions, you have no business messing around with that circuit", and
on Tuesdays and Thursdays I might agree. However, how else do you
learn?
I left a lot of stuff out for brevity, so I hope I don't sound as
crazy as I think I do.
Thanks.
-ph
up again.
learn?
Thanks.
-ph
