E
EJohnson
Hello Everyone;
Once again I am still having trouble with a Zenith Model: A32B41
(9-2003) TV set...a wire-wound sand block? power resistor (5W, 0.68oh
RX3401) keeps burning up immediatly when the unit is plugged in. I go
the schematic and looked over the power supply section and the resisto
that connects to the bridge rectifier (DX3401) and supplies the groun
(-) is the trouble maker. This is the set that was killed by too muc
input voltage (240 not 120). I replaced some components including th
470uF (CX3405) main filter cap and couple other resistors. I don'
understand what keeps burning this resistor...any ideas???
Would the HOT (1167-01) be responsible for shorting the power resistor
Also, If you want to have the full (1MB) .PDF schematic for Zenith G
series, contact me through email and i'll send it to you.
Ejohnson1486(at)yahoo(dot)com
Thank You for any hel
