Rory Starkweather
- Nov 13, 2014
- 77
- Joined
- Nov 13, 2014
- Messages
- 77
The datasheet I am looking at is
http://docs-europe.electrocomponents.com/webdocs/0118/0900766b801185ff.pdf
(I hope that came out as a link.)
Some people have already asked me why I care. Use a uProcessor. My only response is, "Which came first, the LED or commercially available uProcessors? There are actually some benighted souls who claim that it is not possible to use an LED or LCD display without a uProcessor.
Well, I'm having trouble figuring out where the uProcessor ends, and the display starts, so I want to go back to basics until I really understand them.
In Figure 1. Osc 1 - 3 are shown connected. (Pins 38 - 40) Does that mean that they are using the internal Oscillator for their frequency reference?
Kind of the same thing with Ref Hi and Ref Lo (Pins 36 and 35) It seems that what they have done is shorted Ref Lo to In-, Pin 30. Which kind of makes sense, but why is the input to Ref Hi (Pin 36) produced from two resistors, one variable? Is it necessary that Ref Hi be referenced to In Lo (Pin 30) instead of V- (Pin 26)? All examples show pretty much the same thing with different resistance values.
Figure 19 shows a configuration "Developing Under range and Over range signals." Naturally, since I'm paranoid and have no idea what I'm doing, I would like to implement these, but is this a separate IC? The OR/UR circuitry uses several of the segment control pins. Are the majority of the pins left unconnected in the drawing because this is a separate IC? It doesn't show any way to connect to the other IC if there is one.
Basically that concept confuses me.
In Figure 22 it shows a setup for buffering the output from the 7107, which is for LED displays. I haven't looked up the DM7407 yet, but I'll bet it doesn't have 21+ outputs. ??
See you all later.
See you all later.
