Braeden Hamson
- Feb 18, 2016
- 240
- Joined
- Feb 18, 2016
- Messages
- 240
I'm using a standard PWM circuit like so:
https://cdn.sparkfun.com/assets/7/d/0/2/4/52433239757b7fb7798b4567.png
The timer circuit is powered to ~4.25 v with an LM317. The load which at this point is some LEDs is being powered by an IRLZ44N mosfet. Both circuits work, just not together. When put a 3v LED on the output of the 555 IC and connect it to ground it blinks away happily and I can control the duty cycle no problem. When I connect the gate of the mosfet to Vcc the lights turn on as expected and off when I connect the gate to ground. With I connect the gate to the output nothing happens.
Mid post edit, I ran the timer circuit on 5.2 v and everything worked fine. But what I really don't get is that I touched the Vcc with my hand and then touched the gate wire and everything turned on, then I touched ground and it went off. I can use my body to turn the mosfet on, but not a timer IC which can turn on an LED running at a low voltage. The data sheet for the mosfet says the gate threshold voltage is min 1 v and max 2 v so I'm pretty confused.
Save you a google: http://www.mouser.com/catalog/specsheets/international rectifier_irlz44n.pdf
Post post edit: It doesn't work all of a sudden I have power and a good output the transistor cycles with VCC and ground it works. When I connect the gate to Vcc then to the output of the 555 the lights turn off. Mosfets are weird...
