C
[email protected]
I just picked up this meter today at a flea market. At the time of
purchase I noted that the two tiny screws that held the dial plate to
the movement had come loose and were floating around the meter dial.
The dial plate however was secure. I also noted that mechanical zero
was the same whether the meter was standind up or laying down. So I
took a chance on it and it turns out except for a bit of old battery
corrosion, it seemed to work great. When I got it home I removed the
clear plastic cover and then the dial to make sure I retrieved the
tiny screws and any washers that may have come off as well. While
securing the dial back to the meter my small screwdriver slipped at
about the 2 oclock position and.went in and hit the magnet. It didn't
seem to damage anything. After everything was re assembled I tweaked
mechanical zero with the unit in the vertical position and took a
known voltage reading with it. The reading after the accident read the
same as before. It was then that I laid the meter on its back and
noticed that now mechanical zero drifts abot.250 inch downward.
Raising it back up to vertical put the needle back to zero. I know
that I must have done this because it was fine before I slipped. I
know that the tiny counter weight springs which are located at 9, 3,
and 6 oclock have something to do with this delicate balance and I
would like to try to adjust them but I don't know what the procedure
is for making this adjustment so I don't want to make things worse or
destroy the movement completely. Can anyone familiar with adjusting
these movements please advise me on this? Thanks, Lenny
