triple DC voltage switcher
Discussion in 'General Electronics Discussion' started by yves, Apr 4, 2011.
  1. yves
    yves
    Apr 4, 2011
    I am looking for someone to help realize the following circuit:
    here is description in layman's terms
    We have 1 input line (A) where voltage input can be 0 VDC or 5 to 36 VDC
    We have an input voltage (DC) that can be 10 to 26 VDC to power the circuit
    We have 1 output line (AA)
    We would like that
    1) when there is 0 to 5 VDC in the input line (A) that the output line (AA) = 0 VDC
    2) when there is a voltage > 5DVC in the input line (A) that the output line (AA) voltage = the input voltage (DC)
    Once this is solved our real need is for triple version of this circuit:
    1 input voltage (DC) to power the PCB
    3 input lines and 3 output lines (A) => (AA), (B) =>(BB) and (C) => (CC)
    Practical use
    The Voltage (DC) will be produced by truck’s batteries either 12 VDC or 24 VDC
    The input voltage for lines A to C will be produced from parts of the same truck (ignition switch, alternator excitation terminal, other similar).
    NB: this circuit will be working 365 days per year
    Regards
    Yves
  2. (*steve*)
    25,500
    2,840
    The trivial solution is a diode. (due mostly to the fact that the input voltage is defined by you as never being between 0 and 5V)
    You connect the diode with the anode to A and the cathode to AA.
    When the voltage at A is higher than that at AA, current can flow from A to AA (but it can't flow the other way).
    And yes, you can have as many of these connected as you like.
    The disadvantage is that a diode drops between 0.6 and 1.2 volts (depending on current). Diodes also have a current limit that you don't want to exceed, so you may have more trouble finding a diode if the current exceeds 35A or so. For small values (i.e. under a couple amps, no problems)
    What are you powering? Is it imperative that there is no voltage drop? Do you need to prevent current flowing the other way?
    You could use a relay that gets switched on when the input voltage exceeds about 5V, but that won't prevent reverse currents from flowing. (Strictly speaking, your definition also allows a piece of wire to be used here)
    Perhaps some more information (i.e. what is being powered) may be appropriate here.
