Franco said:
I meant that I could not find any written material supporting
that way of using the Mosfets. Anyways, if that approach is
usual there should not be any inconvenient.
Do you have any example when to use that configuration?
If you study your written materials, app notes, etc.,
you'll see the issues of Vgs to turn on the MOSFET, and Vds
are independent; there's no relationship between the two.
The most common situation where Vds is much lower than Vgs
occurs when a MOSFET is switched on and Vds is nearly zero.
And of course we expect to use a reasonably-high Vgs voltage,
such as 12V, etc., to insure that the MOSFET is very well ON
in that case. Later, when Vgs = 0 and the MOSFET is OFF,
the drain voltage is free to rise, e.g. up to the Vd supply
voltage, etc, but consider, why should this be very high at
all? For example, the MOSFET might be acting as a rectifier
in a high-current, low-voltage SMPS, delivering 1.8 volts at
60A to a microprocessor. High Vgs voltages are sill required
to turn on the MOSFETs.
